Home > General > First run |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4943 |
You would know if ace was leaking. Red light would be on
Sun May 21 2017 6:52am |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
I switched from an XKR and life was very strange at first. The TDV6 is surprisingly chuckable but, really, it's made for cruising. And it does it brilliantly. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Sun May 21 2017 7:18am |
IIRC ACE is what reduces the amount of body roll in L320 RRS, it is linked to the Dynamic Response system. In L494 RRS it is the Dynamic mode of the TR system and does the same job but also changes the steering map (L494 has electronic "power" steering) to weight up the steering and it changes the suspension map so it changes the settting more frequently and stiffens up the ride a bit. If you had a saloon car previously then it stands that you were used to a car where the CoG was much lower - in your RRS the centre of gravity is about the height where the rood is in a saloon car so yes the car will tend to roll more, hence LR developing Dynamic electro hydraulic suspension systems - they also enhance offroad performance and can give additional wheel articulation when it is called for. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun May 21 2017 8:07am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
Your RRS is a fully offroad capable SUV, it is not a sports saloon. The CoG is higher - not quite as high as Tim suggests but it is higher than you're used to, after all, it will go cross slope of nearly 45 degrees (you wouldn't get that far as it really would feel like you were about to flip over then and you would back out first!). It has long travel suspension to allow it to go off road. This means body roll is noticeably more than a saloon. This is not a bad thing, however.
Sun May 21 2017 10:04am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Good job you never drove in one of the original Range Rovers or a possibly a 2CV? The body roll on them was very scary indeed
Sun May 21 2017 11:34am |
sonny007 Member Since: 07 May 2017 Location: London Posts: 60 |
I think I'm still transitioning from my 535 to RRS.
Sun May 21 2017 7:14pm |
