Home > Technical > Air con condenser identification 2006 s/c
zetecor
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
Hi guys, I have just had my aircon recharged, it was great for about an hour and then back to warm. I am suspecting a leak. I dont really want to pay for hours of diagnostics and thought I might go straight in and change the condenser to rule it out. Looking in from the front lower scoop I can see a rad with a split in it, there are a few rads/ coolers behind there. Is the one in the pic with the split the air con one if so is this the lightly suspect. Cheers guys.
Post #526443 Sat May 20 2017 5:25pm
If that is green yellow stuff (wipe it with a white tissue) then it's leaking there
Post #526448 Sat May 20 2017 6:57pm
zetecor
Hi, yes it is green, I assume that is the condenser then? thanks for replying mate.
Post #526449 Sat May 20 2017 7:00pm
Eaters
My understanding is that most self-respecting recharge places use a system which checks for leaks before recharging so that if there is a leak you don't pay for something that is not going to work. In other words you should be able to get your money back on the recharge cost! Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #526460 Sat May 20 2017 10:37pm
zetecor
Hi, yes that will be my intention, to get them to re gas for free, just got to tackle the job first. Thinking of doing it myself. I just wanted to confirm that was the aircon condenser and it looked like the suspect. Thanks for your reply.
Post #526470 Sun May 21 2017 9:17am
Eaters
Good plan. Thumbs Up
Just make sure they know first before you fix it that it hasn't worked. Robin
Gone:
MGZTT 190 2.5
Post #526474 Sun May 21 2017 10:09am
zetecor
Cool, will do.
Post #526488 Sun May 21 2017 12:59pm
