Home > General > Just a few issues
Richard039
England 2007 Range Rover Sport Supercharged HSE Java Black
Just a few issues
2007 RR SPORT SUPERCHARGED.
I've recently noticed a few issues with mine
1) R/O/S window doesn't function, neither the front or rear switch do anything
2) the keys used to program the memory seats when you opened the car but this no longer happens. They both open/close the car and operate as ignition keys, as the should but not the seats etc.
3) when you put the car in reverse both door mirrors dip which I would like to disable, especially the drivers side.
Anyone got any ideas?
Thanks Richard
Post #526361 Fri May 19 2017 10:13am
Tim in Scotland
For the mirrors, set the normal position as the dipped position and add it to the memory. I have set the nearside dipped position so I can see if I am about to kerb a nearside alloy. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #526362 Fri May 19 2017 10:21am
for 2 and 3 you need to go into the settings menu on the dash.
use the tip button on the end of the stalk to cycle thru until you get to settings
Post #526365 Fri May 19 2017 11:40am
Richard039
Thanks for the advice, that sorted it. Strangely enough the rear window has started working again. Next job I'd the brake light switch to resolve the other issues.
Post #526602 Tue May 23 2017 1:56pm
Yeah, these cars do this sort of thing. Stuff works fine for ages, then it messes about for a bit, then it's all good again. I'm convinced LR design them that way to keep the traditionalists happy... Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #526622 Tue May 23 2017 8:30pm
Richard039
You're not wrong, having owned a few classics, I wouldn't expect anything else. We all know they love being in the garage
Post #526632 Tue May 23 2017 9:16pm
