Home > Faults & Fixes > ominous low gear clunk sound, transfer box? |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Simple check, Change the transfer box oil and filter the old oil and look for debris. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon May 15 2017 3:59pm |
scenery Member Since: 21 Jan 2013 Location: richmond Posts: 19 |
Thanks,
Mon May 15 2017 4:12pm |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 |
Hi mate I have just had my transfer box rebuilt to £830 mine wasn't a clunk it sounded like a scraping noise like a wheel bearing rover 2,7 sport |
Fri May 26 2017 4:36am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Perhaps the same, having only had the car a small time and still getting used to it I have also noticed a low speed (10-perhaps 20 mph) clunk when apply light throttle but above these speeds I can't say I notice anything. Feels/sounds like it coming from the rear or certainly behind me. |
Fri May 26 2017 7:56am |
When was the fluid in the Viscous Coupling last changed/ checked? You may be suffering slippage in the VC. LR claimed originally that it was "sealed for life" - after a lot of failures in Freelanders "life" was reduced to 5 or 7 years IIRC 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri May 26 2017 8:57am |
When my sport was making the noise it was really difficult to say where noise was coming from it was a rotational scraping noise I swapped both front hubs which included wheel bearings £360 later still same noise swapped rear bearing and corroded back plate just in case it was handbrake shoes catching like I said it was rotational noise £140 later still same turned out to be bearings in transfer box but no clunking sound check ur diff oil and prop |
Sat May 27 2017 7:31am |
