Home > Maintenance & Modifications > Bottom door skirts won't stay on with new clips
paul2415
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
The bottom door side skirt spoilers won't stay on, the previous owner had them all colour coded to match the main body, had the car for about two months, replaced the drivers door skirt with new clips from eBay, stayed firm for a couple of door closes then they pop off at the bottom, removed the skirt and straightened the skirt support and glued them in place so that the front clip remains straight to clip onto the other part of the clip, same happened again, replaced the clips with genuine Land Rover parts, guess what same happens again after a few door closes, the skirt clips onto every clip ok when fitting back on car, now affaid to drive the car in case they fall off, my previous sport never had this before, now a 2010my , does anyone know which glue will glue the two halves together ok? Thanks Confused
Post #525993 Sat May 13 2017 3:06pm
Mine is like this too and I've resorted to duct tape. It's only the ones on the front doors, the rears are fine. Mine are slightly damaged, however, which I've always assumed is the cause.
I have thought about making flush panels to replace the skirts, but it's never been annoying enough to make me get on and do it. Embarassed 2012 SDV6 - it's missing a couple of cylinders
Post #525996 Sat May 13 2017 5:09pm
The LR mod is to use 4 black clips (2 each end I think) which aren't 2 part clips.
Silicon glue is good too
Post #525997 Sat May 13 2017 5:10pm
paul2415
Tried Velcro but the skirt is not tight enough to door frame to attach to, just tried upvc glue on a spare clip which seems to have stuck, was thinking of silicon adhesive between both parts, but was hoping for a LR solution to this, when I brought the clips the parts man said he had never heard of the problem. Is the LR mod available to fit and buy ? Thanks
Post #525998 Sat May 13 2017 5:15pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
The best glue to use is 3m Permabond or any 2 part structural adhesive. Holds anything together forever... 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #525999 Sat May 13 2017 5:37pm
I purchased some copy parts off eBay recently and cheaply.
The part no is on here.
But I'll have a look later
Post #526000 Sat May 13 2017 5:38pm
Topsy
Wales 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi
Mine came off pretty much as soon as I bought it (it was 18m old). Used no-nails, still on 6 years later.
Post #526001 Sat May 13 2017 5:54pm
Part no. DYC500110
http://www.ebay.co.uk/itm/371843607833?_tr...EBIDX%3AIT
These are the ones I purchased, but haven't fitted yet.
Post #526003 Sat May 13 2017 7:02pm
paul2415
I saw those before but wasn't sure if they were correct as the ones fitted were a two part clip, could be worth a try, thanks
Post #526004 Sat May 13 2017 7:05pm
The idea is you put them in the end positions so they don't come apart
Post #526005 Sat May 13 2017 8:16pm
paul2415
Ok will grab some and try them, thanks
Post #526007 Sat May 13 2017 8:29pm
Standard response to any issue, sadly. LR dealerships deny that anything goes wrong with their vehicles and yours is always the only one that has exhibited those symptoms. Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #526018 Sun May 14 2017 7:52am
