Home > General > Splatters of Black grease on tunnel under car help |
Tizzard Member Since: 30 Nov 2015 Location: Nottingham Posts: 64 |
Thu May 11 2017 6:11pm |
Looks like the seal has given up and let the grease out. It will eventually fail as the joint is no longer lubricated, but you should be fine for 3 or 4 months if you need to scratch some money together before replacing the prop. |
Fri May 12 2017 9:38am |
Can the seal not be replaced or is it a case of a new or reconditioned prop?? |
Fri May 12 2017 9:57am |
Theres not really any servicable parts on them. The carrier bearing bush will no doubt benefit from being replaced too. They aren't that expensive or difficult to change (the full prop I mean, not the carrier bearing haha) |
Fri May 12 2017 10:21am |
Thank you for your help and comments. I shall start looking around now for one.👍🏻 |
Fri May 12 2017 10:24am |
