![]() | Home > Technical > No drive in high range, please help. |
It needs a proper code reading doing really. Not all code readers will pick up all of the codes.
The crunching juddering in low range may be the transmission destroying itself with wind up by driving the car on a solid surface............. if you look in the owner's manual it does advise to avoid driving on proper roads in low ratio. When offroad or on low friction surfaces the wheels can spin out wind up but on the road/ higher friction surfaces the wheels cannot rotate the energy back out of the system and something will break. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Hi Tim,
The solenoid isn't silly money but I think access is a bit tricky. 2012 SDV6 - it's missing a couple of cylinders
Thought it was a motor in the side which could be unbolted.
The system has two parts:
Where are you based? We might be able to recommend a good independent LR garage... Visitor from fullfatrr.com
Lukehildred Member Since: 08 May 2017 Location: UK Posts: 3 ![]() ![]() ![]() |
Thanks all for your comments, its much appreciated. I was originally told it was the gearbox and a replacement would be in the region of £4000, hopefully it is not that and a much cheaper solution can be found!
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
ask Woody if he's going to be near you soon, he does a lot of mobile work. This is his profile on the Disco forum http://www.disco3.co.uk/forum/member-woody32.html Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Hey Luke,
It dont take long to get to 5 posts |
just sent you a pm however there was a weird SQL error that appeared when I posted it. Anyway his email is kriswoody@gmail.com. I think his profile on the forum here is "woody32". Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
