![]() | Home > Maintenance & Modifications > Range Rover Sport Brake Light / Suspension Fault |
No it won't be the switch stopping 1 light working.
MattyM Member Since: 25 Feb 2016 Location: Belfast Posts: 9 ![]() ![]() ![]() |
One off the connector pins was pushed in. Had a poke at it and all lights are working fine now. Still getting suspension fault when I stop though. Any idea what it would be Andy? Thanks for the help! |
Lonerangerv8 Member Since: 16 Sep 2015 Location: Cheshire Posts: 83 ![]() ![]() ![]() |
Did they replace the compressor with the uprated AMK unit ?
I'm not quite sure to be honest with you. I think the part was in the region of £460 if that means anything? I'll check the battery and see if it needs charged. |
