Home > General > How much to install a Flappy Paddle kit on 2008 3.6tdv8 RRS |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
Hi Chaps just wondering is pos to install flappy paddle kit to my 08 3.6TDV8 and if so how much would it cost to buy and install?
Sun May 07 2017 2:28pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
When I did my old 09 plate cost over 1k but did use all new parts, including heated steering wheel. On a pre-facelift the the paddle shift will only work with the transmission in sports mode though.
Sun May 07 2017 8:19pm |
Thanks Col,
Sun May 07 2017 9:46pm |
http://www.ebay.co.uk/itm/RANGE-ROVER-SPOR...Sw3v5YttpP
Mon May 08 2017 5:48am |
You do not need to edit the CCF because the pre-facelift never had paddles in the first place, also very few had heated steering wheels. Mani, I did the conversion myself it isn't to difficult really. you will need to buy the circuit boards from Blackbox Solutions for the Paddles there are also extra boards for the Heated Wheel and ACC if you have it and they also have all the fitting instructions etc. on their website it's all pretty straight forward. All the other parts I bought from Dan at Duckworths. With the Heated Steering Wheel, fortunately I had one of the last pre-facelifts and it already had the heated wheel wiring in the harness, although I did need the latest clockspring, according to L/R parts list after a specific vin no. they should all have it fitted but they don't. You can buy the Connector and Lead for the heated wheel in the forum shop to upgrade. Cheers Col |
Mon May 08 2017 7:15am |
Thanks Col
Mon May 08 2017 7:28am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
I did mine for sub-£300, but I did get a dirt cheap 2nd hand wheel |
Mon May 08 2017 11:23am |
Thanks Mikey MY08 RR SPORT3.6TD V8 FULLY LOADED, COOLER BOX, GVIF UNIT, PIONEER AVIC-F980DAB HEAD UNIT, RETAINING 4X4 INFO OEM SCREEN AND TS-WX130DA SUB
Mon May 08 2017 6:11pm |
