![]() | Home > Technical > Slight misfire |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
missfire on start up from cold ? or all the time ? how many miles on LPG ? Does it have a valve saver lube to each cylinder ? 2007 SUPERCHARGED HST |
Hi yes it has a flash lube system on it it has about 91,000 on the clock it was converted a couple of years ago so not to many miles on gas I would think the miss seems to be a bit worse when cold but sometimes I can't feel it either |
Does the flash lube feed each cylinder ?
Will check in flash line but think so no codes I get lean bank on log but that I'm told is normal |
Yeah lean code does show up , but check you have a feed on the flash lube to each cylinder and not one to the intake . That's first job , then we can go from there |
Ok will do are you thinking of valve damage if it does not have flash live to each cylinder then |
Need to rule it out , but you have a few options if it has 2007 SUPERCHARGED HST |
Hi just had a quick look without taking anything off apart from the engine cover I only see 1 pipe from flash line bottle and it looks like it goes in to manifold by the rear of the air intake by the throttle body |
Ok I'm afraid that's good enough for the engine .I don't know why installer's don't fit them to each cylinder |
Ok before I start to rip it apart I think I will try a compression test on each cylinder |
Thinking about it the misfire that shows is inconsistent so I would have thought that to be valves it would be the same all the time but on the diagnostic it's not it's more like electrical |
OK but you will have to strip out the hole intake and fuel injectors to fit the correct delivery system for your flash lube ,so each cylinder is fed , This has to be done ! or you will defo get valve problems . when doing that I would advise you getting the petrol injector's tested and check the valve clearances . 2007 SUPERCHARGED HST |
As the car came with it fitted do I take it to a lpg guy or do I specialist as it sounds as if a lot of people dont know what there doing I have some cleaned coming which was recommended by a specialist lpg company but the way the misfire is it seems more electrics |
Take it to a good log place one that does the surperchaged engines , but to fit the flash lube kit to the engine will not be cheap . Does it misfire on gas and petrol ? 2007 SUPERCHARGED HST |
