Home > In Car Electronics > Downloading Phonebook
Page 2 of 3 <123>
Bodsy
Site Sponsor
Congrats on the purchase Thumbs Up yes I can sort the problem for you.
I'll drop you a message shortly. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #466392 Fri Jul 03 2015 7:22am
TOELPEL
Spain 2005 Range Rover Sport TDV6 SE Buckingham Blue
Big Cry
TOELPEL wrote:
Hi BODSY:
I sent you a pm but have not got an answer yet. Perhaps it was lost.
Here is my proposal to solve my problem:
I am not a mechanic but could talk in my dealer's mechanic to install your kit Disco 4 BT and the other hardware to modify the car. RRS 2005.
The dealer installed apart from the cables two modules. One as the basic phone module and another one which he calls the language module which is English.
The system works but is a pain even to store names with the phone number. Recognising my voice is probably one of the problems. But even numbers which are easy pronounced will not being read back correctly.
Which of the two modules will the disco 4 BT replace? Will it be possibly to give me written instructions on how to connect the items with perhaps a hand drawn plan?
If we can get those and instructions what to remove from the now installed system I will go into that adventure knowing that I could go back to you.
What would be the total price for your hardware?
Hope I am not too much a paine in the .... If you give me your phone number that probably would also help.
Post #521713 Thu Mar 23 2017 4:51am
TOELPEL
Location of but module in RRS 2005
After two years I intend to solve my phone book problem without the help of "Bodsy". He just does not want to cooperate with me. Why?, no idea.
I bought the Nokia BT module of a 2008 RRS which should after change upload my contacts from my iPhone.
However can anybody tell me where the BT module is located in my RRS 2005. Thanks for your help.
Post #521714 Thu Mar 23 2017 4:59am
Alibaba
Austria 2008 Range Rover Sport TDV8 HSE Stornoway Grey
your BT Modul is in the rear of your car in the trunk on the right side, there is a smal door, open it and you can see it.
In the middle of the modul is a screw, Torx, it is only one.
You pair with 2121 and you can see the phone book?
Rolling with laughter
cheers
Alibaba Range Rover Sport TDV8 2008, TV, Screen FFRR, IID TOOL
Post #521717 Thu Mar 23 2017 8:44am
TOELPEL
Thank you Alibaba for the fast response. I'll go for it on
My next free Time. Will post the result!
Post #521736 Thu Mar 23 2017 1:43pm
Alibaba
When you have problems and you need an update for your BT,
i can do this, no problem, then send me a pm or when you have another question about BT3 Nokia and the BT4
In my Range i have the BT4, it works very well.
cheers
Post #521749 Thu Mar 23 2017 4:59pm
TOELPEL
Herzlichen Dank! Thank you very much.
If in need I'll come back to you sending a PM.
Post #521775 Thu Mar 23 2017 10:22pm
foxy69
Wales 2006 Range Rover Sport 4.4 V8 HSE Baltic Blue
Bodsy wrote:
There is, as long as you enter 2121 to connect. I have modules here ready to post out on a swap basis.
I'll drop you a PM in a bit. Thumbs Up
Hi Bodsy. I've just joined the site after buying my first 2006 RRS 4.4. I have connected my iPhone 6s using 2121 but like the others cant access my phone book. If I'm reading it right you have a solution?
Is it possible you could pm with details please? Thanks
Post #524925 Sun Apr 30 2017 5:11pm
foxy69
Hi all
I have just bought a 2006 4.4 rrs. Loving it so far. Got a few issues with it. It's booked in to get the compressor looked at as there was a fault when I bought it but now it's working fine??
Can anyone tell me if I can play music through the Bluetooth connection from my iPhone 6s or is it just make calls?
The conection isn't the best I believe there are mods out there to help me update my rrs into modern times 😜😜
As I am new to the site I am not allowed to send pm's yet so if anyone can help please tell me how to contact you
Thanks foxy
Post #525170 Wed May 03 2017 3:10pm
TOELPEL
In order to listen to music on your iPhone you need a good audio cable, best a screened one and connect the cable to th jack behind the center console. The othe end goes into your iPhone's jack. The radio you will have to set to ext. that's all . Good start.
Post #525172 Wed May 03 2017 3:29pm
foxy69
Thanks for getting back to me I assume I'll have to pull the head unit out to get at the aux jack? 😀
Post #525233 Thu May 04 2017 9:30am
TOELPEL
In my RRS 2005 the jack is situated on the back of the center console
and above of the a/c vent for the back seats.
Easy, just look, nothing to dismantle.
Post #525264 Thu May 04 2017 3:26pm
foxy69
Hi Toelpel, thanks. Found it behind a cover lol doh 😜😜😂😂
Post #525301 Thu May 04 2017 7:48pm
wakeboarderspan
Just purchased an '07 RRS. I'm trying to connect my iPhone 6S to it, which works using 2121 but don't get my phonebook. Is anyone able to help me out? Looking at the posts here it looks as though I need an updated module? Where can I get my hands on one?
Post #526610 Tue May 23 2017 4:33pm
Bodsy
Site Sponsor
I can provide them as a swap service. Drop me an email d3bodsy@yahoo.co.uk Thumbs Up Bodsys Brake Bible
See it HERE
Post #526613 Tue May 23 2017 5:05pm
Page 2 of 3 <123>
