Home > Maintenance & Modifications > gearbox flush recommendations
squizzel
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
I need the gearbox oil changed, and there are 2 places that do it about an hour from me. Alltrack 4x4 and JGS 4x4. Travelling time isn't an issue but I would like recommendations. Is one better than the other, they both equally as good, Has anyone had their gearbox serviced by them and had good or bad experiences.
My car is a 2005 2.7 with the 6 speed box and 96000 on the clock, so I am looking to get it done in the next couple of weeks.
Thanks for your input.
Post #524820 Sat Apr 29 2017 10:27am
GodivaNige
JGS 4x4 did my gearbox flush late last year. No complaints whatsoever, the guy that does the flush is very friendly and encourages you to watch the process with a brew and will happily answer any questions while he does the work. He will also bleed some of your old fluid off into a glass jar so you can see what state it is and compare it to the new stuff going in.
The fluid removed from mine at 60,000 miles was black but didn't smell too burnt.
Your gearbox ecu will be flashed on completion of the flush and you should feel smoother changes as I did.
Was charged £260.00
Post #524823 Sat Apr 29 2017 10:44am
squizzel
Having the software in the box updated could be a big plus. To be honest I really don't think the previous owner before my dad ( it was a car sales mans own car) ever had any software updates done. It was serviced by the garage that did all of his cars. As it turned out they weren't so good. They MOT'd it when he bought it, 3 months later I noticed both the sidelights wasn't working. When I took the holders out there wasn't any bulbs in either of them. So I think I may have to look into having it all checked for software updates too.
Post #524860 Sat Apr 29 2017 6:57pm
He may not mean an update.
Maybe reset the learning after fluid change.
Post #524862 Sat Apr 29 2017 7:06pm
squizzel
Oh ok I can ask them about checking for updates too when I speak to them.
Post #524864 Sat Apr 29 2017 7:29pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
[u]+1 for JGS 4x4.
[u]I had a gearbox flush, both axles and transfer box drained and refilled and a remap done by them last November. I was invited to watch the work take place, given a cup of tea end all my silly questions answered. The guy (cant remember his name) was very friendly and obviously knows what he is doing.
[/u]
Highly recommended Thumbs Up [/u]
Post #524868 Sat Apr 29 2017 8:43pm
squizzel
Well so far it looks like 2 for JGS 0 for Alltrack.
Post #524954 Mon May 01 2017 8:02am
Tim in Scotland
Squizzel, sidelights? Were these the "side-marker" lights in the orange reflectors in the front and rear corners? If so they don't have lamps in them unless the car is a USA/NA spec car. They are required by local construction regs there to have orange side marker lights but not in Europe so they don't put lamps in them at the factory. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #524961 Mon May 01 2017 9:00am
squizzel
No they were the actual white side lights. I wired the orange ones up in my disco 2, they looked really good. Might do the same with this one. But it was the bulbs that were completely missing out of the side lights.
Post #524978 Mon May 01 2017 12:32pm
squizzel
Booked in now with JGS for next Tuesday morning, will let you know how I get on.
Post #525098 Tue May 02 2017 4:40pm
squizzel
Gearbox flush done today, and the oil was black. We were allowed to watch the whole job done from start to finish. There was also an additive put in as standard, and I asked for some Dr Tranny to be added, not that I had a problem, just as preventative maintainance. The drive back was almost all motorway (64 miles) and everything was fine. As I got home I had a vibration start, from around 15 miles an hour upwards. This came through the body of the car and lasted almost all of the rest of the day. Then as soon as it came it went again and so far has stayed away. never experienced it before, So fingers crossed everything has returned to normal.
Post #525737 Tue May 09 2017 9:42pm
Russben
If that vibration starts again stop the car and try touching the rear wheels to see if either of them are hot. I had a vibration from the rear of the car and it turned out to be the nearside park brake sticking on. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #525760 Wed May 10 2017 10:20am
squizzel
I will try that if it happens again. I had just came down the motorway, gone home (obviously hand brake on) was there about 20 minutes then off out again. That's when it started, so it is a possibility. The hand brake was rebuilt 2 1/2 years ago but its done a lot of standing about since.
Post #525772 Wed May 10 2017 12:52pm
Brutus
England 2006 Range Rover Sport TDV6 Autobiography Java Black
+1 for JGS 4x4. Just brilliant and excellent value for money.
Post #525910 Fri May 12 2017 8:59am
