Home > General (L494) > Cornering and Headlights |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Cornering lamps are no longer standard. They were on L320. Even my Autobiography doesn't have them. I think you only get them with adaptive headlamps now.
Fri Apr 28 2017 9:03am |
cmec Member Since: 01 Nov 2014 Location: In the Middle Posts: 20 |
Hi fkarim and thanks for the info. When I say new car I meant that it was new to me, it is fact a 63 plate hse. Any way of determining whether it is fitted with with cornering and self leveling but it just isn't working. |
Fri Apr 28 2017 10:54am |
For cornering lamps, see this thread for where the bulbs are if fitted: http://www.rrsport.co.uk/forum/topic46409.html
Fri Apr 28 2017 11:33am |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Can I ask what may be a silly question - if the complete car is self levelling via the air suspension, what is the point in having self levelling headlights? Surely they are reserved for fixed spring vehicles? 13MY Range Rover Sport Autobiography SDV6 - mine
Fri Apr 28 2017 3:57pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
I suppose it may be different bearing in mind the difference in years yours to mine but on my 2008 TDV8 (with cornering lamps) they are difficult to miss at night. As soon as you slow down to take a sharp corner or turn at a road junction you can see them come on. In addition turning on the left or right indicator at a slow speed (around 25 mph I think) or slower and again they are obvious to see. There's not much point in cornering lights if they don't add illumination to a different part of the road from headlights And mine also has headlights linked to the steering (adaptive?) which you can also see in action if manoeuvring at slow speed - at about 10mph is most obvious. I take insioric's point about self levelling but I think there is some activity built into the adaptive lights if only because I think this is part of the self test ("dance") when you first turn the lights on. And very expensive it is too if they go wrong Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Fri Apr 28 2017 10:37pm |
