Home > Technical > Negative Battery Nut and Bolt
B9BS X
Negative nut and Bolt has sheared of while tightening back the the battery cable, anyone know a part number or am I looking at a new complete negative lead or should I just remove the terminal end and fit a new screw type terminal???
 RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #524399 Mon Apr 24 2017 8:21pm
Bodsy
Site Sponsor
Grind down a M6 bolt edges to fit underneath and use the same nut that you've removed. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #524582 Wed Apr 26 2017 9:25pm
