![]() | Home > General > Odd Occurence |
Hutch41 Member Since: 19 Nov 2016 Location: Northumberland Posts: 95 ![]() ![]() ![]() |
Yesterday afternoon I'd just started a journey when suddenly the engine started noisily racing and the rev counter leapt up to twice it's normal reading.
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 ![]() ![]() ![]() |
Hi pal it could also be a pos transmission fault |
Thanks to both of you
Is it at a gear up-change point? Low transmission fluid or torque convertor issue? |
I must confess that the problem was all my fault.
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
If it bothers you, you can turn the paddles off using the menu available from the steering wheel. Well, you can on mine!
Thank you Jock...I'll check if that facility is available on my car this morning. |
No...the option to disable them doesn't appear in the little window so we're stuck with it.
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
(Must say I don't quite see the point of them and they clutter up the steering wheel)
Oh I see....I did wonder what the reason was.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Ha ha, the silly round gear selector is what appealed to me over the stick - sticks are for manuals...! Maybe it's the same with newer models, but Jaguar have it sorted as my XF (with silly round selector) could have paddles disabled when in Drive, with just a quick change to Sport and have use of paddles. Makes sense to me as D can be for lazy driving, then S for offroad, manual control, or whatever. Accidentally knocking the paddles when in D really frustrates me. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
It begs the question if Jaguar can isolate the paddles when in drive, then why can't the same parent company using the same basic equipment do the same in a Range Rover?
You, should be able to turn them off, I believe, (or a JLR dealership) using a GAP Diagnostic IID BT tool if you have one.
