![]() | Home > Maintenance & Modifications > Rear Pad and Disc Replacement |
SKAJ Member Since: 05 Feb 2016 Location: Berkshire Posts: 14 ![]() ![]() ![]() |
Help Please. I was hoping to replace the Rear Pads and Discs on my 2007 Diesel Sport. The instructions with the parts says. "Drive the Park Brake to the Mounting Position using Land Rover approved Diagnostic Equipment." This I do not have. What does the Mounting Position mean. Am I going to be able to do this job. Many Thanks. |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
I just did my pads and rotors and I referred to this video A LOT. It's very helpful. To answer your question, you need to leave the EPB down as in disengaged. Remove the disk, back off the little wheel, place the new disc on and turn the little wheel the other way to tighten it and then back it off about 6 clicks until the disk can spin. Easy peasy but even I screwed it up the first time lol. The video will help you out.
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
This should be all you'd ever need
Hey Hemo, Would you happen to know if there's any documentation for my plight? http://www.rrsport.co.uk/forum/topic47638.html |
Sent you a link for the workshop manual mate, should be able to find it easy enough on a computer. |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
Try Bodsy's Brake Bible.
That's what I linked to yesterday |
If there's one thing better than a Bodsy brake bible its two!
That's version 1.4, really you should use version 1.6a available in English or French (and soon German) Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Or just get you in to do it Ian 61 AB 5.0 supercharged rocket
the book was WAYYY better than the movie ![]() |
