Home > General (L494) > Coding Hints |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 |
With my previous drive the Board had an area were members could supply coding information for changing settings on the vehicle. I found this very useful in unlocking features that were installed but were not functioning.
Mon Apr 24 2017 10:32pm |
No Have not purchased GAP as there seems to be not much info. I do have the Vag Com lead and software for the SQ5 but will buy the stuff for the RRS when I can see that you can do things other than look up fault codes. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Apr 25 2017 1:21am |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 |
My understanding was it does more than look up and cancel fault codes. Adjusting the suspension heights for example.
Tue Apr 25 2017 1:24am |
It does but is way behind Ros Tech for instant does not tell which parts have failed like the Vag tools do , does tell you fault code but not much more. This of course may be due to the Land Rover limitations. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Apr 25 2017 1:27am |
I wonder what the answer is then? I would like that kind of functionality, especially once it comes out of warranty. I bought a flee bay version for my land cruiser, which was a copy of the Toyota Tech Stream software they use in their workshops. That was good and very cheap ($30.00). Be good if there was a similar JLR rip off... 2017 MY17 SDV6 SE |
Tue Apr 25 2017 1:32am |
I don't know but I bet there is a lot of stuff that can be added because the frame work is installed and just needs the know how . I know of a Touareg member that installed Dynamic cruise control, had to add some hardware but the rest was just software adjustments. I think it is wise to own these tools if ony to keep the service techs on the ball. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Apr 25 2017 1:36am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
The problem with JLR vehicles is that to enable options you need to modify the CCF, or car configuration file, using a software system called SDD (I think that's it).
Tue Apr 25 2017 7:35am |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
Bodsy is also waiting for the MY17 update, as he will be doing a job on mine when it's available. If he hasn't yet got it, I guess no-one has |
Tue Apr 25 2017 12:03pm |
rjwojcik Member Since: 05 Oct 2013 Location: Essex Posts: 27 |
Any update onany tools available for coding? I too have come from VW/BMW land. |
Thu Feb 17 2022 8:10pm |
