![]() | Home > Maintenance & Modifications > DRL Halo lights |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Hello all,
Damn, I was hoping I would be able to contain all the additional wires within the headlight unit 😩
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 ![]() ![]() ![]() |
looks good, like to see some photos when done. The controller has 2 yellow lines for turn signal, what function do these have? |
One is for the left indicator and the other for the right, when you put on the corosponding indicator it turns off the drl on the same side. You don't have to use two controllers, one will work fine, but as previously mentioned, with two controllers it will make a neater job. |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
Andy when I was installing my angel eyes I looked for and didn't find the connector you mention, is this for later models maybe? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Where did you take your feed from Luke ? |
I took the live feed from the live feed to my DRL's, which itself goes to a spare slot in the fuse box in the engine bay. I wrote a post about this somewhere in the forum, let me have a look for it. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Here we go: http://www.rrsport.co.uk/forum/post441576.html#441576 this is an ignition on feed Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Actually I think the early models have it (like my 2005) I notice there is a guy on the D3 forums with a 2008? who can't find it either |
