![]() | Home > General (L494) > KICK FROM GEARBOX WHEN SLOWING ? |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
At what speed? If it's just before you stop it's the 'box going into first. |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 ![]() ![]() |
I get a small shunt which I believe is fuel in the fuel tank, not from the drivetrain.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Put the thing into manual gearshift mode (put it in dynamic and use the paddles to select a gear) and let it come to a stop without touching anything gearshift-wise. In this mode it stays in 2nd. Then you will know if it is the 2 - 1 shift that is causing the jerk or not.
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
I occasionally get a kick when slowing down, tend to be the 3rd to 2nd drop, but depends on how car is slowing down and this tend to happen when its slowdown quickly. Other times its hardly noticeable. |
rrsfan Member Since: 01 Jun 2014 Location: West Midlands Posts: 140 ![]() ![]() ![]() |
Hello Phil You may be right because it feels like it happens when i am down to my last 10-15miles but i will keep an eye on it and see if there is a pattern when this happens but one thing i do know is that it doesnt happen everytime i slow down which tells me it is not normal would you agree ? |
This actually feels like a sharp shunt when the gears change |
will pay attention if this happens when slowing down too quickly as that would explain why it happens only every now and then |
Weegie Member Since: 11 Jan 2017 Location: Scotland Posts: 19 ![]() |
I had this exact symptom when I got our new My17 RRS. For the first few hundred miles, as I accelerated the changes were smooth as you like, but slowing down to a stop there was usually a very clunky kick-down, happened at least once a trip. Never did get round to taking it to dealer and the action has smoothed out completely now (2000 miles done) so hopefully the same result for you. |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
My 2014 does this too. The transmission is not nearly so smooth as my old L320 six speeder was. Progress eh? |
The 'coast' down test is a good way of checking an auto-box: usually a sign the 'brake' bands in the box aren't releasing quickly. On a new motor it could improve with use or need of adjustment - on a old car its usually a sign of significant wear. |
