Home > Maintenance & Modifications > As if the sway bar isn't the only thing... Gas/oily smell |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
Gents,
Wed Apr 19 2017 4:52pm |
Good question,
Wed Apr 19 2017 8:25pm |
BTW,
Wed Apr 19 2017 8:27pm |
You would know if it was diff oil, it smells like cat p*ss
Thu Apr 20 2017 7:24am |
Thank Socast,
Thu Apr 20 2017 11:07am |
With you losing coolant I think that's the issue rather than oil. Finding the leak will be the problem, it could be a hairline crack that opens when the engine is warm (so the coolant evaporates leaving very little trace), when you park and it starts to cool the crack/split seals itself preventing any cold drops from pooling on your garage floor.
Thu Apr 20 2017 11:28am |
Just realised the damp patch you have is on the inlet manifold. You will want to get that sorted asap, the slight damp patch will be due to the small amount of oil that is picked up by the recirculated air from the crank case. The manifold is pressurized by the charger which is whats causing the oil leak, you're also losing boost+air so your fuel trims will be off and the engine will be running lean. I'm surprised it's not thrown an EML |
Thu Apr 20 2017 11:36am |
Socast,
Thu Apr 20 2017 12:46pm |
As you say nothing really out of the norm, but there are a couple for the drivers door. So it might be worth looking at the wiring from the door to the body, see if any wires are worn.
Thu Apr 20 2017 1:06pm |
Perfect. I'll give him a ring and see if he can do it.
Thu Apr 20 2017 3:13pm |
So update on the smell. It's definitely gas.
Sun Apr 30 2017 2:34pm |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
So it's not the fuel tank
Sun Apr 30 2017 4:12pm |
Thank God it's not the tank. When they replaced the Fuel pump and filter they had to lift the body off the frame. Apparently it's the easiest way to do it but takes a loooong time. Hopefully some fuel rail seals will not cost too much in shop time. |
Sun Apr 30 2017 4:28pm |
