![]() | Home > Technical > MAF |
Hi the readings i get at idol are about 1300-1400 mv and it does go up quite a bit as you rev which i did see at about 3600mv any ideas if this is ok |
Does anyone no where i would get what the readings should be would it be the manufacture of the part or from land rover directly
