Home > General (L494) > Rear Pinion Seal Failure
Robocop
Noticed a couple of drops of oil on the drive over last couple of weeks. Thought it was a mates old Landy that visits on our drive, and couldn't possibly be my 3yr old RRS!
Noticed it again today so got under the mota and low and behold fresh oil at the bottom of the rear diff. Sad
Trip to dealers quickly confirmed the rear pinion seal had worn/failed. He said it would be a big job dropping the rear suspension and getting the box out!! Shocked
I thought I was out of warranty by just a month, so was getting ready for a battle, but they said I had extended warranty until Feb 2018.....PHEW Whistle Massive relief.
So its all booked in for a couple of weeks time (need courtesy car) but was wondering, this seems a bit worrying on such a young car? Its a 2014 RRS HSE 3.0V6 with 40k miles.
Anyone aware of a problem or had similar?
Many thanks
Si Thumbs Up
Post #523968 Tue Apr 18 2017 6:18pm
wilf
Had my diff changed at about 6 months old, same issue. Also cured a driveline vibe I had at the time, the two may have been related. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #523976 Tue Apr 18 2017 7:49pm
Robocop
Thanks Wilf,
That's interesting. When I first got the car I had a couple of drives with the technician to locate a vibration. Never found anything and I am not sure that it went away or I got use to it.
Will point them to that when I take it in, and they can look closely at it, just in case it's the cause of this problem.
Thumbs Up ‘65 SVR Corris Grey, Ebony/Cirrus
Post #523978 Tue Apr 18 2017 8:03pm
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Easily damaged when being fitted to the car. Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #523981 Tue Apr 18 2017 9:02pm
Black Bess
My car goes into the dealer for a leaking pinion seal on the rear diff tomorrow. There is no noise or vibration, just a leaking seal, which is not great at 20,000 miles and three years old.
While I was under there, I was not impressed to find the battery of electrical jack plugs arranged in all the weather behind the rear axle line.
Post #524019 Wed Apr 19 2017 3:35pm
Triple7
You using Grange Si? Gone:
2016.5MY RRS HSE Dyn
2015MY Disco Sport HSE
2011MY FL2 HSE
2010MY RRS HSE
2008MY D3 HSE
Post #524041 Wed Apr 19 2017 8:52pm
Robocop
Hi G-man,
Yes, it was bought through them so took it back to them in the first instance.
To my surprise they said I have an extended warranty until Feb 2018 ... thought my 2yr one ran out in Mar this year so that was a pleasant surprise!!
Goes in on 11th so will see what happens. I am aware they don't have the best reputation but they have been good with me.
Rgds
RC ‘65 SVR Corris Grey, Ebony/Cirrus
Post #524390 Mon Apr 24 2017 6:39pm
IRBails
Australia
Interesting when I took my car in for last service, month's ago, I asked would they check the seal. The tech said that they always did as they were known to fail. Basically if there is oil seepage they replace. So I think as self check before a dealer visit would be worthwhile and could save some dollars if the vehicle is out of warranty.Seepage may not get to a drop of oil on the floor for some time, M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #524510 Tue Apr 25 2017 10:47pm
