Home > In Car Electronics > Towing |
Well i think my caravan battery was goosed by being overcharged by caravan charger and my towing socket took battery out of loop and it towed sweet as a nut on way back |
Sun Apr 09 2017 1:53pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Unless you have an unusual caravan battery 'charger' then the usual fitted types are actually a very poor charger due to it's power supply mode voltage which is lower than a charge voltage, so unless you charge your battery on return home with a correct type charger (Ctek and the like) then you are slowly destroying the battery. Charging a battery from a low state of charge with a normal caravan charger is just asking for trouble.
Sun Apr 09 2017 3:22pm |
Thanks for that i was thinking of going down the ctek route as i did check the caravan battery and it had only 5.4 volts so i took that out and put my meter across the positive and negative in the van and there was actually 14.2 volts across them i have had caravans for a few years and have never seen a charger boil the battery like it did and to give me so many problems while towing it i did use the van for the rest of the weekend without the battery and the charger was powering the 12 volt system |
Sun Apr 09 2017 4:06pm |
14.2v does sound a bit high for a caravan power output. But depending on your useage it could still be used for charging along with a D250S Dual (assuming no solar installed), and I'd guess a Ctek D250S Dual is probably cheaper than replacing the caravan charger - assuming it's just running high output voltage and not actually unsafe.
Sun Apr 09 2017 4:42pm |
Thanks for the help i need to look at the charger to make sure it is working correctly first and why the output is high as you say |
Sun Apr 09 2017 5:01pm |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
Does your keyboard not have comma's and full stops? I'm in the shed, I'll be back in the real world in a minute. |
Mon Apr 10 2017 8:52am |
Ha Ha do i need to use them i think not |
Mon Apr 10 2017 9:17am |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
Depends if you want people to read your posts |
Mon Apr 10 2017 9:50am |
We read it. I'm in the shed, I'll be back in the real world in a minute. |
Mon Apr 10 2017 4:12pm |
