![]() | Home > In Car Electronics > Bluetooth connection |
Probably microphone wire is cracked, straight forward to replace if problem comes back. |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Thank's Bodsy
The microphone is in the light unit, behind where you see those small vents above. The crack int eh wiring is usually before the connector. You can wire in a new wire between the radio and the microphone. Just need to feed it through and up the A pillar and along the headlining. |
Much appreciated |
