![]() | Home > General (L494) > Wear on brake pads |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Changed my own pads at 23k miles (only to put in dust free ones).
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
Might be due to a lot of stop a go traffic in the city and of course your driving style,
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
Like wilf I changed mine recently, 18000, and 1 and half years old, front disk have lost around 1mm, and pads only around 2mm. Rear pads wear lot more then the front, then front are around three times larger so its expected. I had issue with pads being stuck due to dust. Replaced with low dust EBC. |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
A gouged disc would have to pretty bad for me to change it personally, not really going to effect braking performance or disc rigidity. |
BTW, I am totally in love with the EBC redstuff pads - the lack of dust is remarkable, and what there is cleans off so easily. Such a difference from the OE ones. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
A small bit of grit or similar can get stuck at the leading edge of the pad and mark the disc. Mine has a small groove in the front disc (I replaced the fronts on mine 2 years ago) with no obvious reason. Warranty won't generally cover discs & pads as they are seen as consumable items. I'm in the shed, I'll be back in the real world in a minute. |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
There is no warning system that will tell you about uneven wear or brake pad wear, until the pads become very low and the wear contact brings on a warning light.
