![]() | Home > Maintenance & Modifications > BREMBO REFERB - READING? |
tone 123 Member Since: 18 Dec 2014 Location: northeast Posts: 36 ![]() ![]() ![]() |
i would check your brake pads. |
Milblunder Member Since: 28 Jan 2017 Location: Berkshire Posts: 24 ![]() ![]() |
A garage mentioned that the calipers are not returning fully and dragging hence loads of break dust far more then ever seen on my other cars |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
These guys do a collect and send service, and are brembo specialists. Also do a drive in out service if you fancied a few days away. http://www.brakecaliperspecialists.uk |
Hmmm.. Be very wary of casual comments made by garages. The RRS is a big heavy beast and takes a lot of stopping hence the front brakes especially tend to make a lot of dust. If you have a problem it is more likely the pads are seized in the caliper than the pistons within the caliper are seized. Are your pads original equipment or aftermarket? Aftermarket pads can be worse for dust than the originals. Refurbishing Brembo calipers properly is an expensive job especially if you are having to pay someone to take them off and reinstall them. Some companies don't use genuine Brembo seals or don't bother changing them at all. You are probably looking at £500 just to do the fronts for a proper job. Before refurbishing I would recommend you try changing the pads and discs and take great care to clean up and lubricate the appropriate parts. If your discs and pads are not very worn then you could even try just dismantling, cleaning and lubricating. If you really want to have the calipers refurbished I can thoroughly recommend this company: http://pro-calipers.co.uk/ Ask to speak to Tomas. He did my classic Porsche calipers and it massively improved the braking feel. Night and day difference. 2008 MY Java Black TDV8 HSE ![]() |
Paddi cheers buddy seems great advice |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Not sure if this helps but maybe worth a go.
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 317 ![]() ![]() ![]() |
The age they are generally at, a calipers rebuild wouldn't hurt. Try Big Red. |
