Home > Faults & Fixes > Connector found, should it be loose? |
geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702 |
That has a blank in it by the looks so should be for a part not fitted to your car so see if you can find the hole in the chassis that the black plug came from and reattach it |
Tue Apr 04 2017 1:35pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
I think it's part of the tyre pressure monitoring system. Presumably you don't have TPMS which is why the connector is blanked. 2012 SDV6 - it's missing a couple of cylinders
Tue Apr 04 2017 2:21pm |
