![]() | Home > Faults & Fixes > slight lurch/judder around 2nd 3rd @ slow speed |
On the old shape 2005-2013 there is a well known issue similar to your description. Cure might be a transmission control module software update. Best thing to do in this case would be take it to a good independent specialist and get them to read the fault codes and check for latest software version updating if necessary. 2008 MY Java Black TDV8 HSE
timsport Member Since: 01 Apr 2017 Location: north essex Posts: 2 ![]() ![]() |
yeah maybe,
No, the symptoms you describe don't usually cause a fault code to be stored.
