![]() | Home > Maintenance & Modifications > RRS Running boards |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 ![]() ![]() ![]() |
ebay? but you'll have to find someone to fit for you (local indy?) or do it yourself. Merc C220 estate Sport AMG
yorky22 Member Since: 13 Sep 2013 Location: york Posts: 50 ![]() ![]() ![]() |
Hi Bill
there's a few threads you could search for. i was looking at getting some but haven't got round to it yet.
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
I just got mine (Genuine Range Rover) for £680 delivered courtesy of Duckworths on this forum. Ok so I have to fit them myself or get someone local to do it but that should be fine. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Ive just fitted some to mine. From eBay at £138. They're aluminium with 3 section brackets each side and feel very sturdy. I used Powerful UK video on YouTube to fit them and they seemed pretty near identical. First side took about 2 hours to do. The other side took about an hour. The only thing I found useful (apart from the usual tool kit) was to have an 8mm tap and die set to clear the crud from the mounting holes under the sills as they are not protected from road muck by any covers. The ones on the side of the sill are covered by tape and so were clean. With your RRS being that much newer, it probably won't have much crud anyway.
