Home > Technical > Ace / Active Stabilization System |
SAS32 Member Since: 05 Feb 2017 Location: UK Posts: 27 |
It's a sealed system and thus the level won't change unless you have a leak, and you don't want to run the pump low on fluid as it's a �1k part!!
Sun Mar 19 2017 11:49pm |
Check the connections to the valve block, one of them may have come lose causing the incorrect pressure reading. |
Mon Mar 20 2017 12:17pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
You need a full code read done. There are at least 4 codes that have C1119 at the start and all relate to hydraulic pressure in the DR system.
Mon Mar 20 2017 8:05pm |
Edmundz1 Member Since: 28 Jun 2016 Location: London Posts: 13 |
Thanks for your replies guys, still had no luck. Changed the filter and fluid as its coming out black but still no joy. Is there any software out there that i can use, at the moment I'm using wow autocar.
Tue Mar 21 2017 8:21pm |
Sorry to be a pain, when you say full code read regarding the fault code C1119 underneath that code my software says -0. Would that relate to anything?
Wed Mar 22 2017 11:50am |
Fault now fixed, ended up being dirty fluid blocking the solenoid on the valve block. Flushed system with new fluid and fault now clear. |
Wed Mar 29 2017 5:55pm |
Good news. Thanks for letting us know the outcome. One to add to the collective knowledge. 2012 SDV6 - it's missing a couple of cylinders
Wed Mar 29 2017 8:13pm |
