Home > Technical > Key Fob not opening central locking and immobilising engine
Jen
I have a 1998 P38 and one morning the key fob stopped opening the central locking but the key fob sends a signal. I have manually started the engine using the EKA code and the engine starts so it was not a flat battery that caused the problem, then once the engine is shut off the immobiliser kicks in again. I know this is probably not the correct forum for this Range Rover but I don't know what else to do, has anyone got any advice or can you recommend someone who might be able to fix the problem in the London area?
Post #521145 Fri Mar 17 2017 10:19am
Socast
Are you sure that the key is sending a signal ?
Post #521148 Fri Mar 17 2017 10:41am
Jen
Well, the red light flashes when the buttons are pressed and the batteries have been changed, so as far as I can tell its working. I only have the one key.
Post #521149 Fri Mar 17 2017 10:50am
Socast
Sound's like you may need a new key, or at least need it reprogrammed.
I don't know of anyone in the London area I could point you towards unfortunately.
Post #521153 Fri Mar 17 2017 11:03am
Jen
OK, thank you
Post #521154 Fri Mar 17 2017 11:04am
donny dog
It may not be connected, so it may not help, but I had a similar problem several times on my wife's Evoque. I identified which fuse operated the keyless go, removed and replaced it, and it worked fine. It happened about three or four times in the life of the car, which was annoying, but the above cure always worked. (Indeed, I even kept a couple of spare 5 Amp fuses in the car in case I dropped one in the ridiculously inaccessible fusebox). You'd no doubt get the same result by disconnecting the battery, but that might cause you other inconvenience having to re-set things.
Post #521162 Fri Mar 17 2017 11:36am
Jen
Thanks, I will try that.
Post #521163 Fri Mar 17 2017 11:52am
Scrumpy
I had a similar problem , caused by myself, removing and reconnecting a fuse which Censored the BCM!
I used Belgravia Garage, despite the name, they are reasonable, specialise in Range Rovers and are very, very thorough and professional.
They will even do a free health check, no obligation but lots of recommendations. 2016 RRS SVR Estoril Blue
Post #521237 Sat Mar 18 2017 12:51am
