Home > Faults & Fixes > Pulling out of junction |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 |
Unfortunately it is a common issue - its either something you get used too or put it in Sport mode
Fri Mar 17 2017 8:08am |
Bulletsaints Member Since: 26 Feb 2017 Location: Southampton Posts: 59 |
Fri Mar 17 2017 10:53am |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
The hesitance is less noticeable after egr blanks fitted. Nanocom Evo |
Fri Mar 17 2017 10:58am |
Is it a matter of just blanking them or does it need plugging in to tell ecu the egr are removed etc ? 2005 tdv6 |
Fri Mar 17 2017 11:16am |
As I understand it 05 and 06 can be blanked without software upgrade 07 on requires the upgrade so you should be ok Nanocom Evo |
Fri Mar 17 2017 11:24am |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
My car is a 2005 and I blanked my egrs off without ecu light triggering. You can buy the blanking kits on ebay for around £15, its a bit fiddly as the egrs are low down in the engine but if you have the tools, its a diy job. It made a lot of difference to initial response from the engine. |
Fri Mar 17 2017 11:33am |
Great....I need to look in to this, do the egr's be removed or just blanked, I'll see if I can find a link with pictures as makes it a little easier |
Fri Mar 17 2017 12:13pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Contact a site sponsored mobile mechanic like Bodsy or Geoff
Fri Mar 17 2017 12:37pm |
