![]() | Home > General > Loss of directional indicator noise |
all linked through a sounder in the instrument pack. if you are good at electronics you can replace the speaker otherwise you have to replace the instrument pack or live with no sounder. Bodsys Brake Bible
Leetaylor Member Since: 18 May 2016 Location: Sunderland Posts: 7 ![]() ![]() ![]() |
Thanks for the info. If it can be replaced then I can easily change it out,
the sounder is soldered on the main board of the instrument pack, so go carefully.
Hi ,
accyis Member Since: 05 Feb 2010 Location: Lancashire Posts: 109 ![]() ![]() ![]() |
Hi. How did you get on replacing the sounder? |
