Home > General (L494) > Front parking sonsors |
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 |
That front sensor behaviour is the same as my MY15.5
Mon Mar 13 2017 1:09pm |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 |
Regarding front parking sensors: I am sure that they can be set to either be on or off by pressing and holding down the button for around 6 seconds.
Mon Mar 13 2017 1:38pm |
Jimbo095 Member Since: 21 Sep 2016 Location: Lincolnshire Posts: 145 |
I find that too, thought it was my driving style but if I'm only lightly on the brake the stop/start doesn't kick in. Add a tad more pressure and the engine cuts out... |
Mon Mar 13 2017 2:09pm |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 |
That's a design feature so that when you are in crawling, stop/start traffic the engine doesn't stop and start dozens of times. I have a hard job making the stop/start system work at all on my vehicle, but that's another story.
Mon Mar 13 2017 2:33pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Thanks all for the info. Very helpful.
Tue Mar 14 2017 9:20am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
I am told that disconnecting the secondary (small) battery will inhibit the stop/start.
Tue Mar 14 2017 11:37am |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
Stop-start will soon stop working on its own when the batteries go flat!
Tue Mar 14 2017 11:45am |
I am told that the little "stop/start" battery isn't used to start the engine, the main battery always does that. The little one powers the electrics while the engine is stopped.
Tue Mar 14 2017 2:37pm |
Yes, I meant that it operates the stop/start system, which is why apparently that is disabled if you disconnect it. Given that people have disconnected it and everything else still works, that would suggest the middle-sized one operates all the other electronics/accessories. |
Tue Mar 14 2017 2:44pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 865 |
This is correct when you think about it you want the high drawing current as close to the source as possible , the loss of power by running heavy leads from the back of the car to the front would be very inefficient. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Mar 14 2017 8:49pm |
But the starter battery is still in the back. |
Tue Mar 14 2017 8:51pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
Regarding front parking sensors, mine come on whenever reverse is selected (or if I push the button) but turn off once your doing over about 10mph or thereabouts. Robin
Tue Mar 14 2017 11:10pm |
The battery that powers the starter motor is the large Battery which as you say is at the back, I was reflecting on the R50 which had the accessory battery in the rear and the start battery in the front. My bad?? And the one thing I did say correctly was running leads a long way does lead to loss. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Wed Mar 15 2017 10:21am |
Well, I sorted out the sensors at the front. It was as Violetpiano described above. By pressing and holding the button on the side of the display screen I was able to make them come on and stay on at all times, just like my old Sport.
Fri Mar 17 2017 1:33pm |
