Home > General (L494) > OBD Protector - Cat 6 |
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 |
I'd try another insurer. I've just upgraded to a 2017 a/b & a Cat 6, as fitted as standard was accepted. I was told by insurer that the R/R sport a/b is group 44 & a Cat 5 is only required on groups 45 & above. current 2015 hse dynamic, grey. |
Mon Mar 13 2017 4:53pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
My new car was refused by 4 or 5 insurers, including the ones that covered my old Sport, because of the pointless keyless entry system.
Tue Mar 14 2017 9:10am |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
My insurer didn't even ask if it had a tracker (SDV8 A/B)! |
Tue Mar 14 2017 12:10pm |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
I thought this issue had gone away since LR did some software updates. They moved the OBD port and locked Key module so you cannot code a new key.
Tue Mar 14 2017 12:42pm |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 |
This shouldn't be an issue and sounds like an ill informed insurance company. No new keys can be paired without replacement of the KVM. |
Sat Mar 18 2017 9:02am |
Wyn Mills Member Since: 03 Jun 2017 Location: South Posts: 6 |
I've just posted a new topic on this before doing a search. Sorry!
Sat Jun 03 2017 5:43pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
Why are you sell BB? SVR 2018 in Santorini Black. |
Mon Jun 05 2017 12:30pm |
Because I regard the L494 as an inferior car to the old Sport in many ways that I did not appreciate when I bought it. I expected an update over the old car but it is just full of electronic frippery, most of which doesn`t work very well. My main disappointments are:-
Tue Jun 06 2017 11:43am |
Pretty certain that you must have bought an HSE and not an HSE Dynamic if you don't have low ranges as Dynamics have low range as standard and the full TR system.
Tue Jun 06 2017 2:47pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
+1 on the "should have gone "dynamic" "thing.
Tue Jun 06 2017 3:29pm |
Yes, I did not check for low range and buying used it is a case of choosing from what is available. However, both my previous RR had low range (it is a Range Rover right?) so I assumed it would be there and I am miffed that the salesman didn`t bother to mention it. Presumably most customers don`t even know what it is.
Thu Jun 08 2017 12:44pm |
One reason for the L494 HSE not having low range (even at launch it didn't have it) is that the transfer box adds 20kgs to the vehicle weight and 99% of owners never use low ratios so to save further on VED the HSE Non Dynamic was offered. It's is one of the things that people buying an HSE tend not to realise although the HSE non dynamic could have the On-Road/Off Road pack option that added the transfer box and low ratios but the price difference to the HSE Dynamic was then small and with the Dynamic version you didn't just get the low ratios but also the trick electro-hydraulic handling pack and an e-diff (in addition to the centre diff) on the rear axle as standard. Up to 2016MY the HSE Synamic also had a more powerful engine - 306bhp producing 700NM of torque whereas the HSE had less, but now they have the same tuning.
Thu Jun 08 2017 2:53pm |
Ah, interesting. That`s good to know.
Thu Jun 08 2017 2:57pm |
Cobstar Member Since: 26 Aug 2010 Location: UK Posts: 45 |
Black Bess - I just automatically switch stop start off when I start the car up. Irritatingly on the D4 this leaves a bright orange ECO sign lit on the dash. The SO's X£ just has a discrete orange light alongside the stop start button beside the steering wheel.
Thu Jun 08 2017 4:23pm |
