Home > Maintenance & Modifications > Can someone help with my Range Rover suspension issue
German-wheels
Yes I have left the fuse out, had to put it back in to drive the car quickly earlier.
Post #520586 Fri Mar 10 2017 8:42pm
Socast wrote:
You'll need to leave the fuse out over night. I wouldn't read too much into it lowering.
I forgot to mention, rather than pulling the fuse you could have disconnected the battery (bit quicker and easier).
If you disconnect the battery you really need to leave it to go fully to sleep before doing so. 2012 SDV6 - it's missing a couple of cylinders
Post #520591 Fri Mar 10 2017 10:01pm
German-wheels
After lifting the car to off-road setting and back to normal height the results are below (from top of arch to middle of centre cap)
Osr 45cm
Nsr 46cm
Osf 46cm
Nsf 47cm
It didn't seem to drop as much this morning after the fuse was removed but have tried again today to see as I didn't measure this morning.
Post #520633 Sat Mar 11 2017 8:38pm
should be
front 461mm
rear 465mm
But the question about the fault remains
Post #520686 Sun Mar 12 2017 5:12pm
