Home > Technical > Dynamic response Lateral accelerometer C1A97-62 *SOLVED*
Sharpy1980
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
I have done a search and all I can find is a diagram showing component locations and it list the accelerometers as no 4 & 7 which show as 1 being above the rear view mirror and 1 under the bonnet, the trouble is I can't locate the 1 under the bonnet and I'm not sure which one is the lateral one so has anybody actually worked on these and know where to find it as I have a fault code of C1A97-62
 Clickadeeclick
Post #520478 Thu Mar 09 2017 7:17pm
On the 08 TDV8, the lower accelerometer is on the chassis rail near to the Dynamic Response valve block. That's below the drivers seat, by the way. Have a look under the driver's side and you should find it. 2012 SDV6 - it's missing a couple of cylinders
Post #520504 Thu Mar 09 2017 11:56pm
Sharpy1980
That's it then?
That's odd I found that yesterday and thinking that was it I unplugged it but gained another fault code for Pressure sensor signal C1A09-16, I though it a bit odd as it didn't look like a pressure sensor as it had no pipes or other connections to it,
Now you saying that has made me realise there isn't a pressure sensor listed in the components for the DR.
Thanks for your help Clickadeeclick
Post #520514 Fri Mar 10 2017 7:47am
Sharpy1980
Solved
Well it seems after going round and round the houses I finally found out why I had a fault with my lateral accelerometer and why it showed a pressure sensor fault when I unplugged the lateral sensor, the plugs for the lateral sensor and the pressure transducer (no.19) in the diagram were swapped, really obvious now I found it but not before going around the houses as the live data in the IID isn't for the lower lateral sensor but for the lateral sensor within the yaw sensor which caused a little confusion but hey we got there in the end, no more warnings on the dash... for now Thumbs Up Clickadeeclick
Post #523741 Sat Apr 15 2017 7:39pm
loquitosk8er
Argentina
hi! i m trying to find the sensor that you replaced but i cant find it on the chasis. do i have to dissasambly something to reach the sensor?. will you please help me finding it? thanks!
i have a 2007 land rover discovery 3v8 HSE
Post #584078 Tue Jul 16 2019 10:08pm
Sharpy1980
It’s just under the drivers (uk) door but looking up from under the car, it’s actually mounted to the body not the chassis it’s basically on the inner sill and there is also a valve block right near it Thumbs Up
P.S just checked on a LHD it’s on the same side so is obv passengers side on yours Clickadeeclick
Post #584094 Wed Jul 17 2019 9:49am
Disco_Mikey
You wont find it on a Disco3. DR/ARC was never an option
Post #584099 Wed Jul 17 2019 11:29am
cosworth89
Sorry to revive this but the guys who have taken body off my l320 have left this sensor plugged in and ripped the wires out of the connection block. Anyone have a photo of the wires going to the block please?
Post #646351 Sat Jan 18 2025 12:30pm
