Home > Technical > Adaptive Dynamics fault - REAR |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Can't help but these guys come recommended
Tue Mar 07 2017 7:16pm |
Having the NSR upper arm replaced and then you've got a warning that states the NSR solenoid on the shock isn't right I would suggest that whoever replaced the arm needs to fix it. It'll either be a nipped wire or disturbed plug. The AD Warning will be caused by this fault, the ECU signal might just be a blip, clear the faults and see if it comes back. |
Wed Mar 08 2017 9:11am |
Julianp Member Since: 15 Mar 2015 Location: Midlands Posts: 6 |
Thanks for those DrRob - I'll take a look at both. Dudley is pretty close.
Wed Mar 08 2017 2:58pm |
4 wheel alignment will need doing too after changing any suspension arms Visitor from fullfatrr.com
Wed Mar 08 2017 3:40pm |
Yep - it was booked in, but I cancelled in case it all has to come back off and then had to be done again. I'm sure it won't, but it just seemed prudent until the AD issues is sorted. I'm doing 10 miles a day at the moment, (the joys of local contracts!), so not doing too much damage to the tyres. |
Wed Mar 08 2017 5:13pm |
