![]() | Home > Maintenance & Modifications > Might need new rear wheel bearings 2010 Range Rover Sport SC |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 ![]() ![]() ![]() |
Hey guys,
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I'm no mechanic but isn't a knock more likely to ge a bush rather than a bearing? I would have thought a bearing would give you more of a grinding noise especially audible at low speeds |
Well that's what my ex-mechanic friend said. I'm going to his house tonight so he can take it for a spin and let me know but I had both front left and right bearings replaced so the sound coming from the rear is familiar. The front bearings did not grind but they did knock. when the tech put it on the lift he checked for play and there was a good 1 inch of play in both front wheels... No grind at low speeds, just some severe knocking that would get worst when I was taking a turn. The knocking I hear now seems to be caused by the same things, turning left or right and no knocking in a straight line but some knocking when I hit certain bumps. All this sounds too familiar. I hope it truly is a bushing as I imagine it is a bit easier to change than bearings especially in these cold temps. We'll see tonight I guess. |
Not necessarily,
