Home > Technical > Brembo caliper removal?
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
How easy is it to remove the entire brembo front calliper?
I want to paint them, but want to do it with cans rather than brush on paint.
Post #520171 Mon Mar 06 2017 10:42pm
Fluid is main issue.
Need tobleed afterwards.
And stop fluid coming out while off.
Post #520179 Tue Mar 07 2017 5:16am
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Re: Brembo caliper removal?
Paint them ? Yours look nice and sparkly anyway ! Not like mine which are a bit...er, dull 🙁
Post #520189 Tue Mar 07 2017 9:10am
Danv8
Lol, that's just dust and sand..
Post #520191 Tue Mar 07 2017 9:18am
Paddi
This is one of those questions that has more than one correct answer:
It is easy if you have the necessary tools and experience; but quite a challenge for a beginner. To minimise fluid loss you can either clamp the flexible hose (frowned on by some) or buy some brake pipe and connecting parts and make yourself a blanking piece to screw in. You'll still need to bleed the brakes after refitting.
If you are only looking to paint the caliper without changing the discs and pads at the same time then I'd recommend you just clean up and mask off very carefully and thoroughly and paint in-situ. In all honesty it doesn't need to be perfect because you can't see the caliper very clearly through the wheel anyway and your beautifully painted caliper soon gets a bit dirty.
This was mine after I sloshed a bit of 2 pack paint on with a brush:
 2008 MY Java Black TDV8 HSE
Post #520232 Tue Mar 07 2017 6:20pm
