Home > Faults & Fixes > Reversing sensors |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
Lots of info on here for sensors, seems to be quite common. While the mrs holds it in reverse you can bend down and listen to them. They make a very faint clicking noise, but that does not mean its a sensor. Reading other member posts its also common for the loom to fail, and in other cases the receiver module in the boot fails. So even if you do find the sensor out it might be the loom . I am facing exactly the same job this weekend, bumper off to get to the wiring and sensors . An OBD fault port reader will let you know what the diagnostics system reports.
Mon Mar 06 2017 7:37am |
