Home > Maintenance & Modifications > 2005 sc engine oil change question |
0w oil may flow quicker but it doesn't provide enough protection to a worn engine, it's oil pressure that you need and being as the oil is pressure fed round the engine the difference between the 0w and the 10w reaching the top of the engine would be marginal, however the higher viscosity of the 10w oil will provide better protection. The 0w oil being thinner would lower oil pressure due to it being able to easily flow out of the worn bearings etc. The higher viscosity of the 10w will raise the oil pressure back towards what the engine had when it was first built.
Wed Mar 01 2017 6:38pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
Tim is absolutely right. The only "but" I would put in here is if you change your oil in smaller mileage intervals like I do. As an example I went a total of no more than 5000 Kilometres (3125 miles) when I last changed my oil. for this reason I just do it through the top as opposed to the old fashioned way. If you are mileage is much much higher then yes, drain it from the bottom and get all that crud out. As for thicker vs thinner oil. The tolerances on a brand new engine relax a little as the engine breaks in and wears.... After about 5 years it is well set and perhaps a slightly heavier oil would not be such bad idea.... I've also been giving this a lot of thought as I usually go with the recommended 5W20 however, this summer I may go 5W30 just for a touch more thickness and protection. The winters in Ottawa may be really really cold but the summers are tremendously hot so a slightly thicker oil for the summer months seems to make sense. |
Sun Mar 05 2017 4:13pm |
