Home > Technical > Spare Wheel Diameter.
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi Lads
I am sure this question has been asked before ,but I can't find anything when I search.
At present I am running 22" wheels and tyres on my Sport ,I have the standard spare wheel under the car , If this spare wheel and tyre is a different overall diameter than the 22" wheels and tyres I am running on the car, Would I be able to use this in an emergency or is it going to throw up Faults or worse cause damage to the Transmission ? Confused
Cheers Jock Thumbs Up
Post #519819 Sat Mar 04 2017 12:07pm
Camelrock
Best thing to do is remove the spare and see how much of a difference there is. I would think that it would certainly cause problems yes. I run 20's on mine and had a standard 19 spare changed it for a matching full size. Do you want to take the risk ? I would personally get a matching spare 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #519842 Sat Mar 04 2017 3:45pm
donny dog
Surely the overall diameter is the same, the larger rim just having lower profile tyres? Even then, it would only be suitable as a 'get you home' spare.
Post #519851 Sat Mar 04 2017 5:36pm
Jock 77
Re Spare wheel Diameter
Thanks for the reply lads
I will have a look at both wheels and tyres and compare both sizes ,think there are a few sites on the Internet where you can compare tyre sizes to find out the exact difference. Will try and get the sizes on Monday when I am off. I think mine will also be the original spare.
Not sure if a 22" would go under the car so would need to look into that too. I did think that it could possibly cause problems but its one of those things that tends to slip your mind.
Post #519880 Sat Mar 04 2017 8:51pm
Camelrock
My full size spare fits under the car it's tight but it does fit 275/45 20 is the size 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #519890 Sat Mar 04 2017 10:38pm
Jock 77
Re. Spare Wheel Diameter
Thanks Camelrock
I will also check the Diameter of your spare against the diameter of my 22" wheel and tyre and that should also give me an idea if its going to fit under the car.
Post #519905 Sun Mar 05 2017 8:21am
Jock 77
Re Spare Wheel Diameter
Hi lads just thought I would post an update
Checked out the tyre sizes on the Internet . Tyres on the car are 285 /35 /22 which are diameter 29.85" (758mm).
My spare is 255 / 50 /19 diameter 29.04" (738mm).
Going by the calculator 22" is 696 Revs/mile against 19" which is 716 Revs/mile.
So 20mm difference in diameter ,I am trying to source a 22" spare at present and hopefully might just get it under the car going by the diameter of Camelrock's spare 275 / 45 /20 which is 29.74" (756mm) diameter.
Cheers Jock Confused
Post #520155 Mon Mar 06 2017 10:06pm
donny dog
If outside diameters of tyres are this different, how does the speedometer/milometer cope if you change all the tyres?
Post #520174 Mon Mar 06 2017 10:52pm
