![]() | Home > General > Spec of new shape SE |
Topsy Member Since: 06 Jan 2017 Location: Swansea Posts: 48 ![]() ![]() ![]() |
Hi
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 ![]() ![]() |
I have the new shape SE which I obtained new in 2014 for the very limited period that this model was on sale in the UK. It was pulled by Land Rover after only about 6 months from launch due to their inability to cope with demand and the higher profit margins on HSE etc. The main differences (as best as I can recall) are the absence of flappy paddles (I have big hands and they just got in the way when I tested a HSE) and the terrain response system is the one fitted to the original Sport, Disco & Freelander. I have found no appreciable difference in off road performance between the two systems and my vehicle has coped remarkable well with testing off road trips. I am not sure but I think the basic HSE only has the single range box but the Autobiography has the high/low transfer box. The standard seats on the SE I believe are manual adjustment with less adjustability - I specified Style 2 powered seats and also had front fogs fitted. I am happy with the standard sound system but you should be able to upgrade this as an easy after market fit. The only negative is that it is supplied with 19inch wheels as standard and no one sells all terrain tyres to fit the exact size. So I bought a second hand set of 20inch which will take a General Grabber AT. That said it is definitely a better ride on the larger profile tyres for 19 inch wheels than 20inch and you do not kerb 19inch wheels.
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
I've still got a brochure with the new shape (RRS2) TDV6 SE in it. I can check anything you want to know if you still have any outstanding queries. |
Hi
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
Hi.
Hi
Only 4 SEs on LR Approved today... Visitor from fullfatrr.com
It's a good forum this is. Usually plenty of good info and advice.
