![]() | Home > General > Trailer module |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Depends what sockets you have?
mgriggs Member Since: 23 Apr 2016 Location: Oxfordshire Posts: 19 ![]() ![]() ![]() |
Thanks,I will try that I have 12n & 12s sockets all work but does not turn off rear park sensors. 2012,Range Rover Sport HSE,SDV6,Nara Bronze,Cold Climate Pack,Memory Pack,Dynanic Pack |
Unfortunately I'm +4000 miles away from my iiDTool and RRS so can't see the options, but there was something for the twin 12N & 12S. I know that with my 12N&12S and settings for 13 pin, it does cut my park sensors so works well. It was all fitted prior to my purchase, although I intend changing to 13pin sockets.
The wiring kit is a Right Connections kit part no:37190512RC for the RRS 09/11 onwards
With those options I'd choose the 13pin. At the end of the day the wiring from the car is just routed to the appropriate pin configuration in either 13pin or 12N & 12S sockets.
Thanks Dennis and I will read the PDF later. 2012,Range Rover Sport HSE,SDV6,Nara Bronze,Cold Climate Pack,Memory Pack,Dynanic Pack |
I've just realised what you wrote about it working but doesn't cut off the park sensors - can I assume it still leaves your RRS reverse lights on aswell?
I only use the 12S socket to charge the battery with the Ctek charger,the parking sensor are a pain when I have the car trailer on and put it in reverse,so hopefully they will turn off when I input the setting with the iid tool. 2012,Range Rover Sport HSE,SDV6,Nara Bronze,Cold Climate Pack,Memory Pack,Dynanic Pack |
So the 12S isn't used? Just get a 12S plug then and link out the appropriate pins, use it as a dummy plug.
That's assuming the RRS2 does it that way.
RRS2? mgriggs mentioned his 2012 facelift RRS so that was what I was going with, and mine being 2013 I thought likely the same?
Yes I would say the button is easier than carrying a dummy plug round.
