Home > Maintenance & Modifications > Steering/front suspension jumping |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
IMHO I would change the complete arms as quite frequently the originals have to be cut off due to the bolts being sized.
Thu Mar 02 2017 4:48am |
robertevans68 Member Since: 28 Jan 2015 Location: Cheshire Posts: 5 |
Ok thanks, there's no banging or knocking at the minute so I'm going to try and last until better weather 😀 |
Thu Mar 02 2017 5:26am |
If you drive very slowly and dab on the brakes you should hear knock,, a sign that the front lower arms / bushes are worn. Might also be worth having a good look at the wheel bearings while your busy as these don't last forever either
Thu Mar 02 2017 6:00am |
