Home > General (L494) > Minimum disc thickness
wilf
Anyone know the original and minimum disc thickness (f and r) on a MY16 3.0 TD6 HSE dynamic ((Brembo calipers)?
Thanks in advance. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #518716 Thu Feb 23 2017 3:21pm
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
workshop manual has 'Service - limit marked on the disc' for both F and R disks.
Front disc thickness: New 34.0 mm (1.33 in)
Service limit marked on the disc
Rear disc thickness: New 25.0 mm (0.98 in)
Maximum disc run out:
Front 0.050 mm with wheel fitted
Rear 0.070 mm with wheel fitted
Post #518749 Thu Feb 23 2017 8:14pm
wilf
Thanks.
I will whip off the wheels and see what is marked on the disc hubs. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #518789 Fri Feb 24 2017 9:37am
SRE
Spain
Sorry wrong post Embarassed In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #518790 Fri Feb 24 2017 10:02am
wilf
So.........
Front discs - min thickness - 31mm
Rear discs - 21mm.
My fronts measured up at 34, ( they must have been more than that when new) so lots of life yet. The rears you cannot measure without dropping the caliper off, which I didn't bother with, as the "lip" was tiny anyway.
Pads front and rear getting low, probably will need changing within 5k miles. I will try some EBC "ceramics" to see if they cut down the dust.
Anyone tried Red or Yellow stuff pads on their cars? They do both, not sure which ones to go for.
Gawd, those Brembo front calipers are huge! MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #519058 Sun Feb 26 2017 3:42pm
nigethecat
Scotland 2008 Range Rover Sport TDV8 HSE Java Black
Had EBC Red Stuff pads on a couple of cars (but not RRS) and found them to be a big improvement but you can sometimes get a squeal at low speeds... certainly stop you quicker! D3 LHD - great car !
RRS 2008 HSE in Java Black
Previous Cars Edited highlights
Alfa 4C
Audi S5
Disco 4
Alfa 939 Spider (250bhp)
Freelander 2 Dynamic
Lotus Elise S1
Post #519079 Sun Feb 26 2017 8:01pm
IRBails
Australia
wilf wrote:
So.........
Rear discs - 21mm.
Good to know what use your disc's have had ? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #519104 Sun Feb 26 2017 10:54pm
wilf
22k miles of "normal" road use, I am not too hard on brakes. Lots of those miles on M-way journeys. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #519124 Mon Feb 27 2017 11:12am
Canary
I'm about to buy EBC red stuff ceramics low dust variety absolute bargain if they stop all that darn brake dust grrr!!
I'll let you know how I get on with these. MY18 SCV8 Satin flux silver
Gone:
MY19 SV VELAR AUTOBIOGRAPHY firenze red
MY18 SCV8 Yulong white- perfect 👍
MY16 SDV8 SANTORINI BLACK - perfect 👌
MY64 SCV8 DARK BLUE - nightmare car
MY64 SCV8 FIRENZE RED - loads of annoying issues
MY15 SDV6 FIRENZE RED - perfect 👌
MY12 SDV6 DISCO4 IPANEMA SAND - perfect 👌
MY09 TDV6 SPORT BLUE - lots of issues
Post #519207 Mon Feb 27 2017 8:13pm
wilf
That would be really useful, I think I am a month away from fitting some max.
Reading the descriptions on the EBC site, I suspect redstuff will be what I need in preference to yellow. After all, this is a 4X4, not a Seat Cupra R. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #519209 Mon Feb 27 2017 8:21pm
Olly-ibiza
Iv had red stuff on mine, noticed no difference at all between them and genuine brembo pads. Im fitting 6 pots this week and will go with genuine brembo pads spiteful Range Rover Sport tdv8
Post #519217 Mon Feb 27 2017 9:02pm
matsoutback
Australia
To combat that evil brake dust, I use Autoglym Wheel Protectant. It has worked well on our cars, and reduces brake dust buildup almost magically. Wink
I have no affiliation with Autoglym... 2017 MY17 SDV6 SE
Post #519223 Mon Feb 27 2017 9:14pm
Canary
Olly are you saying you saw no difference in brake performance or no difference in brake dust?? MY18 SCV8 Satin flux silver
Gone:
Post #519229 Mon Feb 27 2017 10:03pm
Olly-ibiza
Performance... my wheels are black so iv no idea about dust spiteful Range Rover Sport tdv8
Post #519301 Tue Feb 28 2017 11:52am
wilf
Anyone know the EPB re-set procedure? (for after you have changed pads)? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #519597 Thu Mar 02 2017 12:35pm
