Home > Technical > Using aux on my rrs 2006
Stumpydok
United Kingdom 2006 Range Rover Sport TDV8 HSE Rimini Red
Hi all im' a new member just got a 2006 RRS TDV8 and cant workout why my iphone nor a brand new MP3 player wont play through it. Tried my laptop and this works fine ? any ideas ?thanks in advance.
Post #519208 Mon Feb 27 2017 8:18pm
nigethecat
Scotland 2008 Range Rover Sport TDV8 HSE Java Black
Hi Stumpdok and welcome !
How are you trying to connect to the stereo ? I use the Aux connector on the rear of the centre glovebox and run a cable round to the speaker jack on my ipod, this way the ipod can sit in the coin tray... this seems to work fine, also the volume setting on the aux connector is very low so turn the volume setting on your player to maximum and then adjust via the stereo... D3 LHD - great car !
RRS 2008 HSE in Java Black
Previous Cars Edited highlights
Alfa 4C
Audi S5
Disco 4
Alfa 939 Spider (250bhp)
Freelander 2 Dynamic
Lotus Elise S1
Post #519213 Mon Feb 27 2017 8:49pm
Stumpydok
plugged in the same but wont work ,only my laptop will work
Post #519218 Mon Feb 27 2017 9:03pm
Volumes need to be high
Post #519220 Mon Feb 27 2017 9:10pm
nigethecat
Have you tried a different aux cable? If the laptop is working then the connections sound ok but worth checking.. when playing from laptop are up you using WMP or iTunes? Never tried to play music via my iPhone as I think this would mean I was unable to access the Bluetooth phone function once aux is connected. D3 LHD - great car !
Alfa 4C
Audi S5
Disco 4
Lotus Elise S1
Post #519222 Mon Feb 27 2017 9:14pm
Stumpydok
yes i have .just dont know why its not working. i have know idea what format they are ,or supposed to be tho.[/url]
Post #519388 Tue Feb 28 2017 10:02pm
d-9
I have my iPhone plugged into the aux port, playing Spotify. When I use the Bluetooth for calls, it pauses the audio. I don't think it starts playing again when the call ends thou.
The aux port is analogue, it doesn't really have a 'format'. It is a line level input, so you need a device with a line output, or if you are using a headphone output, you need to turn it all the way up.
Post #519393 Tue Feb 28 2017 10:34pm
Stumpydok
Ok thanks will try that.
Post #519497 Wed Mar 01 2017 7:17pm
d-9
Tested this more today, if my iPhone is playing when I take a call, it resumes the music after I hang up Smile
Post #519547 Wed Mar 01 2017 11:12pm
flindersstation
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
I've tried two cables with my iPod and the sound is barely audible. Suspect a bluetooth extender will be the same. I'm going to burn some CD's as that is working a treat!
Post #572288 Thu Jan 03 2019 4:20pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
You can use a headphone amp to step up the gain between your device and the aux input which will up the volume but be careful not to overload the input (you would know as it will sound horrendous). I do on my 2012 sometimes.
Post #572305 Thu Jan 03 2019 7:47pm
garrycol
Australia
The volume on the iPod needs to be turned right up - the max you can without distortion then control the volume from the radio. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #572347 Fri Jan 04 2019 12:27am
Scrumpy
Not sure if this helps but I had the same problem on my 2005 RRS. I was trying to play an iPod (160Gb classic) through the aux port in the car using a 3.5mm jack from the headphone socket on the iPod but the volume was rubbish.
I then read on here somewhere about using a 30pin(?) iPod connector (the one that goes in the bottom of the iPod) to a 3.5mm jack in the aux port and it worked a treat!
Hope that helps. 2016 RRS SVR Estoril Blue
Post #572357 Fri Jan 04 2019 9:35am
you got a link to that cable scrumpy? or lightening equivalent ?
Post #572382 Fri Jan 04 2019 12:21pm
Scrumpy
Andy, I just used something like this
https://www.amazon.co.uk/AAA-Products-Bett...3.5mm+jack
There are lots of ones available and probably better going for a more expensive one but it gives you the idea.
Here's the Lightning equivalent but I never tried that with an iPhone so can't say whether it has the same effect.
https://www.amazon.co.uk/iPhone-Going-Head...3.5mm+jack
It made a big difference to the volume output! 2016 RRS SVR Estoril Blue
Post #572384 Fri Jan 04 2019 12:30pm
