productnation
Oil leak and coolant loss TDV8 | |
I've got a '07 RRS TDV8 and a few weeks ago the coolant pipe going into the top of the engine just below the turbo pipes blew off, luckily when it happened I was right next to a pull in so travelled a matter of meters and had the engine shut off before most of the coolant drained.
I refitted the pipe, refilled the coolant at the side of the road and all seemed fine, temperature was normal and heaters worked so assumed there were no major air locks. A few days later I noticed it was losing coolant so I took it to a garage to be bled properly but it is still losing coolant. A friend in the unit next to mine is a breaker so we got it up in the air and can't find any leaks, the garage that bled it also confirmed no leaks.
I have done a mix of journeys, the longest being 90mins, temperature remains normal, idle sounds and power output is the same as usual.
On top of the coolant loss there appears to be an oil leak from the rocker cover. Has anyone encountered this on the TDV8 and is it just the case of a new gasket?
Obviously my concern with the coolant loss is that the engine has been damaged when the pipe came off, I would really appreciate people's thoughts on some causes and solutions to both issues!
Thanks,
Alex
Sat Feb 25 2017 2:56pm |
