Home > Maintenance & Modifications > Rear washer won't dispense washer fluid
CANROVER
Canada 2010 Range Rover Sport Supercharged Santorini Black
Hi all,
Hoping someone can help me. On my 2010 RRS S/C, when I activate the rear windshield washer fluid it will squirt out a weak jet of fluid onto the FRONT windshield..... Has anyone else experienced this? No fluid comes out through the rear jets.
Thanks in advance lads Wink
Post #518780 Fri Feb 24 2017 7:30am
donny dog
Sounds like a blockage in the pipework to the rear washer, creating a back pressure which bleeds past the valve to the front system. Maybe try flushing the system through to remove any sludge.
Post #518782 Fri Feb 24 2017 8:19am
I think someone had this.
Before they got round to replacing the pump, it warmed up and fixed itself Laughing
Post #518805 Fri Feb 24 2017 11:57am
CANROVER
Thanks for the reply Andy. It's plus zero temps across the pond for a few days but the eddy effect these things produce at high speeds REALLY gum up the rear hatch and lift gate button so I'm hoping it's just a clogged jet. I'll give it a good wash today and see what I find. Thanks. Wink
Does the 2010 Range Rover model have 2 separate pumps and if so where exactly are they?
Post #518821 Fri Feb 24 2017 3:28pm
1 pump for front and rear windows.
Pump in front left wheel arch
Post #518834 Fri Feb 24 2017 6:30pm
Pump on the far right.
the black hose comes down directly down from the fillter neck
[URL=]
[/URL]
Post #518851 Fri Feb 24 2017 8:11pm
d-9
How does it work with one pump? according to the manual it is meant to wash the front windscreen when you press the end of the stalk, and wash the rear screen when you pull the stalk towards you. Is there some kind of selector valve?
Post #518858 Fri Feb 24 2017 8:59pm
Motor direction is reversed to do the rear.
Post #518860 Fri Feb 24 2017 9:02pm
d-9
Thanks. Mine has the operations switched (which is super annoying), I assume the pipes are on the wrong outlets?
Post #518863 Fri Feb 24 2017 9:06pm
Suthy
United Kingdom 2011 Range Rover Sport SDV6 Autobiography Santorini Black
my hoses were on the wrong way round, when I pulled the stick the rear washer would work and the front wipers, easy fix though swapping the hoses.
Post #518865 Fri Feb 24 2017 9:21pm
Better pictures from someone else
Black_64 wrote:
Post #518958 Sat Feb 25 2017 4:56pm
Johnski
Not that it matters, but......Mine appears to have two pumps plus I thought another one for the Headlight Washers does anyone know? I seem to be able to have front and rear washing together, Embarassed which shouldn't be possible if motor needs to be reversed? I often click on rears & press button and pull up the stalk to clean the screens before moving off. (To remove sea salt) or do I have a fault? Whistle
Having two main pumps have been confirmed by LR Hatfields Pickering in the past, although they didn't say if a mod, it's got a very large water container which holds over a gallon of washer fluid, not same as in photos above. John
Post #518986 Sat Feb 25 2017 10:07pm
Bobby
If you also have headlight washers, then there will be 2 separate pumps like this..
Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #519003 Sun Feb 26 2017 4:38am
Yes they have 2 pumps. A high pressure/volume one for the headlights (seen on the left).
And a smaller one for the windows on the right.
I think in ~1989 manufactures released that they did not need the cost of 2 motors (1 for front and 1 for rear) by doing some cleaver stuff in the motor (a direction flap?) it could all be in one unit with a modification to the electrics too.
This had advantages such as
1) Cheaper
2) Less weight
3) less holes in the bottle and less likely to leak.
4) Improved assembly time
Those are big bottles above. Maybe not the biggest I have seen, but they aren't small.
If you have water coming out the front and rear at exactly the same time, and when you don't want it, maybe you do have a fault.
Post #519027 Sun Feb 26 2017 10:56am
